so i have a rule to set the category automatically on file creation depending on the users input in the file.
this works fine.
i have iproperties in the file that i need to see in vault, all the mapping is correct(i think).
this works fine.
BUT when in the file if i set which category the file should be in none of the iproperties show up when i check the file in.
attached is a picture showing 2 files Test.ipt & Test - Copy.ipt
Test-Copy.ipt is a copy of Test.ipt but i filled in the field ' Authority' so the rule in Vault runs to automatically set the category.
Solved by jcorson8499. Go to Solution.
as you see test.ipt has the property _Item No. filled out with 1.2.3.4
Test- Copy.ipt does not.
