Vault General Discussion
Distinguished Contributor
jcorson8499
Message 1 of 3 (154 Views)
Rule to set category on file creation, lost iproperties
154 Views, 2 Replies
02-06-2013 07:23 AM
so i have a rule to set the category automatically on file creation depending on the users input in the file.
this works fine.
i have iproperties in the file that i need to see in vault, all the mapping is correct(i think).
this works fine.
BUT when in the file if i set which category the file should be in none of the iproperties show up when i check the file in.
attached is a picture showing 2 files Test.ipt & Test - Copy.ipt
Test-Copy.ipt is a copy of Test.ipt but i filled in the field ' Authority' so the rule in Vault runs to automatically set the category.
had to set the properties in the category
jcorson8499
Message 2 of 3 (153 Views)
Re: Rule to set category on file creation, lost iproperties
02-06-2013 07:24 AM in reply to: jcorson8499
as you see test.ipt has the property _Item No. filled out with 1.2.3.4
Test- Copy.ipt does not.
jcorson8499
Message 3 of 3 (118 Views)
02-08-2013 08:37 AM in reply to: jcorson8499
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
