Currently, we need to create individual rules to automatically assign category to files. We are aware of this limitation that OR condition cannot be used with in a rule.
i.e, FileName endswith ".doc" OR ".xls" OR ".ppt".
we need to create the following rules instead
FileName endswith ".xls"
FileName endswith ".ppt"
Madhan
Hi, Patrick,
I recall that it was working for me. However, I will check this for you and update you soon.
Madhan
Hi Patrik,
I tested this and it works fine for me. I am sorry that in my previous reply I mentioned to include the extensions with in double quotes. I realized that it does NOT work. However, it works without the quotes.
BTW, I did not modify the existing rule instead I just copied and rule and changed the file extensions. Here I am attaching the screen snapshot for your reference.
Hope that helps.
Madhan
Hi, Patrick,
You are very welcome. As I recall, due to some technical limitation it could not be implemented. I will keep you posted if I get any further information on this.
Madhan
Hi Patrick,
Another note, if you have multiple lines in the same rule, it actually means "AND" between the lines. I believe that's the reason why it did not work.
I just thought of passing the above information.
Madhan
Hi. My file rule didn't change the category "on check-in", only on "adding". What can be wrong with it or is it as supposed?
Rules are only applied on creation of the file within Vault, in other words adding the file to the Vault. But the rules aren't applied each time a file is checked in. There is a tick box in the rule creation GUI which allows you to choose if the rule is applied on file creation or not. The only other time a rule can be applied is via the change category tool, scroll to the end of the list and there is an option to apply the category based on the assignment rules.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
I really don't understand this function "Apply rules on object creation” . Summing up, if this is unchecked, It will act like the rule were disable (nothing happen when you add a file)?
Thanks for any explanation.
Pablo
Has this issue been fixed yet or in the queue to be? As far as I can tell, I still need to create separate rules for each file type if I want to "OR" them.
