It's quite confusing to use share central files in this integration.
1 Where should I put the Revit central file? In a network folder, or just in Vault?
2 There are two kind of configuration. One is the share path. The other is the mapping option in the add-in menu.
Which one should I choose?
I hope some detailed guidline to make the workflow start to run.
Thanks in advance!
its supposed to work in conjuction with revit server
DarrenP
Hey there,
Please have a read through the wikiHelp article here:
http://wikihelp.autodesk.com/Vault/enu/Help/Help/0001-Using_Va1/0054-Understa54/0000-Add-in_-0
The Revit integration works by checking in the shared model on sync - recording versions of this central model. The model is usually on a network share and can be used with Revit Server.
