Hi all,
Can anyone confirm if Revit LT is able to be used with Vault (i.e. the Autodesk add-in)?
I am looking at putting together a proposal to shift our company parts management into Vault, but as we have very limited licenses of full Revit, I need to know first if Revit LT is compatible.
Thanks in advance.
Solved by DarrenP. Go to Solution.
no it does not
you need vault pro for full Revit
Which Applications Support the Vault Add-in?
http://help.autodesk.com/cloudhelp/2015/ENU/Vault/files/GUID-334CC890-1F12-429C-9D6A-B964327CA590.ht...
DarrenP
