Hi
When auto updoading data, is there a way to have the system reognize the correct revision of the file?
Solved by clastrilla. Go to Solution.
Not that I know of. What I've done is to map the file revision to a UDP in Vault. You can then use the Revise command to essentially call up the revision of the file, and make that the Vault revision. All this is done after you've uploaded though.
You can refer to this post:
