In our early project phases, if we have to send prints to the customer, we use a Proposal revision scheme with an Alpha revision character. Once the customer has signed of fon the project, we want to change scheme to our project revision scheme, which uses a numeric character.
Sometimes the proposal may be at revision A or B or even higher. When changing revision schemes, Vault wants to set the next Primary revision as one numeric character HIGHER than the coresponding Alpha character. ie: A-1, B-2 etc... problem is, our initial released revision for projects is 0.
Is there anything short of deleting the Item and losing all of the Proposal history, to force the Item to revision "0"?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by cbenner. Go to Solution.
This just got weirder.
I have 2 Items set to Category "Proposals". This categeory is set to use an Alpha revision scheme. One is at Rev A, the other is at Rev B. On both of them, if I try to change revision, and change the scheme from Proposal to Project (numeric), they BOTH try to set the next Primary to "1". The first revision of the project scheme is "0". It seems like it would try to set "A" to "1", and "B" to "2".
It obviously wants to go backward on the one Item.... so why won't it go all the way back to "0"?!
Chris Benner
One sided conversation, but I figured out the mystery. The Items had beec assigned as Project. The engineer then told the drafter they needed to go to the customer for approval (not all of them do), so the user changed the category to Proposal. Vault now sees rev 0 on the project as having already been used. Which puts me into a predicament as to how to handle these in the future.....
Chris Benner
