Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Revision number not updating
4 REPLIES 4
tmccar
447 Views, 4 Replies
I'm using the Engineering category and as far as I can tell, it's using the Standard Numeric format.  Yet the revision numbers are not incrementing - all revisions are showing a rev. 1 in Vault. Why would this happen?
4 REPLIES 4
luttena
in reply to: tmccar
Hello and thank you for your post. There are a few possible reasons for this. First, I have to ask if you are doing anything that would require a revision bump (Revise, state transition that bumps the revision)?
Adam
Adam Luttenbacher
Sr User Experience Designer
Autodesk, Inc.
tmccar
in reply to: luttena
Hi Adam - I was just testing that the revision numbering was working - so I checked out the doc,  added some text in the document, and checked it back in. I was expecting to see the revision number increase, as per the AOTG.
luttena
in reply to: tmccar
That explains it. The version number will increase when you check in a new iteration of the file. If you'd like to see the version history you can add the Version property to any of the grids in the client.
Adam
Adam Luttenbacher
Autodesk, Inc.
tmccar
Cool, thanks
