Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Revision and Rev Number Mapping
0 REPLIES 0
Message 1 of 1
petr.vanek
635 Views, 0 Replies
Hello everybody,
I've run into the problem which have a croud of people - relationship between UDP "Rev Number"
and "Revision" system property.
I can't populate Revision into .idw drawing.
I've set up this configuration:
- UDP "Rev Number" has Autodesk default configuration mapping, i.e.
Entry    Provider    File Property    Type    Classification    Mapping                   Create
File      Inventor    Rev Number    Text     Standard          Vault<->Document    Yes
UDP "Rev Number" is associated to relevant categories, of course.
- System property Revision mapping is:
File       Inventor    Rev Number    Text    Standard           Vault-->Document    No
Notice: I've managed mapping with a new file in Vault.
The same Revision configuration described e.g. Max Bodnar in his report "Revision mapping"
in 11-07-2011 here at the Vault forum.
Then I check in some new .ipt plus .idw to the Vault, UDP property for .idw has "Rev Number"
from .idw Inventor template. It's all right.
After running through the .ipt livecycle (together with .idw)  the  Revision number
is increased, but UDP "Rev Number" in .idw is still the same. After sync properties it's the
same too.
There is an old value there. What surprise!
Important notes: I haven't got Property compliance: Noncompliant equivalence, fortunately.
Recreating the Revision mapping doesn't help.
It doesn't work, it's all.
Could you happen to know how solve this neverending problem?
Enjoy your day.
Sonenberg
0 REPLIES 0
