Under the Change Order List can someone tell me what the Review Status column is used for. I have many ECO's and 20% of them have checked boxes under the Review Status column and the rest are not checked. What does it mean if there is a check or not a check in the box. Also is there a way to manually check or uncheck the box.
Robert
Solved by yuhui.zhang. Go to Solution.
Hi Robert,
This column mainly reflects the status of associated items.
The column would be checked if the associated items are all in In Review or Released.
The columns is unchecked if the associated item has a WIP item or there's no associated item.
Third status is Indeterminate when the change order is Cancelled or Closed.
Hope it helps.
Best Regards,
Fay
