Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Return the files of the folders
4 REPLIES 4
trafo2009
178 Views, 4 Replies
Hey People
I need create a window to navigation on the vault folders, but i don't find the funtion for this.
att.,
4 REPLIES 4
in reply to: trafo2009
Hi trafo2009,
Were you looking for this?
Via Vault Explorer, select any vaulted file, RMB
> Go to working folder.
Let us know if this is not the case.
Rgds,
Chear Huat.
Hey
People I need create a window to navigation on the vault folders, but i don't
find the funtion for this. att.,
trafo2009
Hello Chear Huat,
I am programming an application in C#, objectRX + windows forms.
The idea of developing some tools (2) whom they make CheckIn and CheckOut, without using the available ones shears autosdesk in order that the user has the minimum of work. Besides working with few licenses and avoiding of the users forget of LogOff.
About this problem i decides using TreeViews. \o/
But falls in another problem. What is a command of CheckOut
code:
file_id = long.Parse(GridFiles[GridFiles.Selection.ActivePosition.Row, 0].Value.ToString());
folder_id = long.Parse(treeFolders.SelectedNode.Name);
FrmLogin.docSvc.CheckoutFile( folder_id, file_id, "MachineDarcy","D:\\", "Checkout", true, true, out bytes);
These commands return the error 1013: 'Cannot get file (file id is invalid).'. But theses variables are correct.
Att.,
Darcy Buss Neto
Develop Edited by: trafo2009 on Mar 2, 2009 8:26 PM
This sounds like youre trying to automate the check in and check out of
files using your own interface to Productsream/Vault Explorer?
I'd avoid this if at all possible as checking in files through Vault
Explorer should be avoided as it will not keep links to related files.
-Hywell
trafo2009 wrote:
> Hello Chear Huat, I am programming an application in C#, objectRX +
> windows forms. The idea of developing some tools (2) whom they make
> licenses and avoiding of the users forget of LogOff. About this problem
> i decides using TreeViews. \o/ But falls in another problem. What is a
> command of CheckOut code: file_id =
> 0].Value.ToString()); folder_id =
> long.Parse(treeFolders.SelectedNode.Name); FrmLogin.docSvc.CheckoutFile(
> bytes); These commands return the error 1013: 'Cannot get file (file id
> is invalid).'. But theses variables are correct. Att., Darcy Buss Neto
trafo2009
Hello Hywell,
I will be going to try to do so. the Check Out gave right.
I am going to see how the checking works.
On the VaultExplorer, I used TreeView.
Darcy Buss Neto
