I have set the Vault option to Restrict Item Lifecycle Changes to Change Orders. I am currently the only Administrator in the Vault, but my users are still able to manually change Item Lifecycles.
Any thoughts on this?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by cbenner. Go to Solution.
When I tried to reproduce your issue by Right click on an Item and choose "Change State", I get the following dialog:
1. Could you describe the steps your users use to change the state?
2. Are they always able to manually change the state or does it only happen under certain circumstances?
- Matt
I found the answer. Previous admin had placed all users into a group, and gave the group admin privelages. We were not using Items or ECO's at the time. Once I reset the roles on the group the behavior was as expected.
Thanks for your response!
Chris Benner
