Michael,
The answer to THAT question (sorry) is no.. however, if you know the
specific file location in the filestore, you could manually go into the
filestore of the backup and pull it out. That said, it would be akin to the
needle in a haystack, so I wouldn't suggest doing so.. At that point, you'd
probably save time by restoring it, pulling the file out, etc.
Is there a special case that you've fallen into that would require you to
restore a single file from the Vault backup? I'm interested in the
particular reason.. maybe there's a different/better way to go about it..
Bob
"Dave Hoder" wrote in
message news:5072202@discussion.autodesk.com...
I think he meant a single ipt.
"Bob Henry (Autodesk)" wrote in message
news:5072127@discussion.autodesk.com...
Michael,
You can detach Vaults you don't want included in the Vault backup. When
you're done, simply re-attach them. The same goes for the Inventor content
center libraries, but those must be detached from the CC Library Manager.
Bob
wrote in message news:5072083@discussion.autodesk.com...
Is it posible to restore a single file from a vault backup? or is it the
whole backup or nothing?
Michael Kidd
