I am trying to connect to a vault 2010 database using Vault Manufacturing 2010. I get the following message: "Autodesk Vault Manufacturing 2010 is not compatible with the Vault Server running the following applications: Vault Server 14.1.63.1"
This is the same version number that the client has.
But I can connect to it with just a "Vault 2010" client, which is 14.0.63 !
How can I connect with the Vault Manufacturing 2010 client?
you have to have the vault pro 2010 server installed
you can't connect to a basic vault server with the vault pro client
DarrenP
they should be on the inventor 2010 media
DarrenP
I don't have the media unfortunately.
If I can download the client from somewhere, is it ok to go ahead and install it? (I assume it's free software).
if your on subscription you can download it from the subscription website
DarrenP
