Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Reports and Colors
4 REPLIES 4
Ktelang
381 Views, 4 Replies
Reports and Colors
Hello Everybody,
I have created multiple categories and have assigned to object inside of Vault Professional 2013.
I used default available File By Category.rdlc to generate a report. i assigned the color scheme to
the same as well. But for some reason. I am not able to get that color scheme to show up in the
report.
Am I missing some crucial step.
* BTW I am new to Vault Professional 2013
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
4 REPLIES 4
Senthil_Kumar
in reply to: Ktelang
Please have a look at the following links which may help.
http://underthehood-autodesk.typepad.com/blog/reporting/
http://wikihelp.autodesk.com/Vault/enu/Help/Help/0001-Using_Va1/0054-Understa54/0077-Add-in_-77/0080...
http://www.youtube.com/watch?gl=SG&hl=en-GB&v=5mjIwWHTy4I
If you still cannot get it work please send me the RDLC - Report Template file that you are using.
Senthil Kumar
Development Manager,
Autodesk, Inc.
Be sure to check out the Vault Help!
Ktelang
in reply to: Senthil_Kumar
Thanks Senthil,
I looked through the youtube video and tried Vault in CAD rdlc and was able to see the categories by color
and was able to map those as well to the model.
But when I try using File By Category rdlc which comes default with the installation it does not show the colors
I am not expecting it to map those colors to CAD but when I try generating a full report atleast I should be able to see
that colors on the bar chart, correct me if I am wrong
Please find the attached image and rdlc file attached
Please advise
Senthil_Kumar
Thanks for your reply and the files. Now I understand the issue. Rather confusion.
If you use "File By Category" report, the report comes with a chart showing Which Category is in What State. X- Axis Category and Y - Axis by State.
If you use " File by Life Cycle State" then it is opposite of the above. X by State and Y by Category.
So for your case "File by Life Cycle State" might help.
Being said for your case the best template without confusion is "Project Dashboard".
Hope the above helps. Please let me know if you need any further help/information.
Senthil Kumar
Autodesk, Inc.
Ktelang
I think it worked for now.
Thanks for your
