If I could ask a few questions:
- Does this problem happen for new files that you add to the vault? e.g. can
you add a file to one server and access it from another server? ?
- When you mention seeing this errors in the log every day: are the errors
for the same set of files [ids]?
- About how many error entries do you see in the log files on a given day?
- Have you recently run a scandisk on your harddrive with the filestore? If
these are file checksum mismatches, disk problems can sometimes be the
culprit.
Paul
