Good Day All
I have file replication setup on a test basis. I am able to add files from both locations, and can see the files I have added from both locations. However when I try and copy the files added from one site to the filestore at the next site I get the following error: "The file is only available from the following sites which are not accessible at this time: MDP-WS529651". This error occurs on both my sites when I try and get files from one site to another. I have also tried to get the sites to replicate at certain times, but get errors in my concole logs:
11/2/2010 12:45:12 PM Could not replicate resource 'MCG-B78-SH02-CV01-MD-010-06 0A.PDF' version 1 from avaiable sites. Located in the filestore at C:\FILESTORE\TESTVAULT\TESTVAULT\000\000\000\000\000\000\102\102_103_1.PDF.
11/2/2010 12:45:12 PM Replication continuing because orphans were allowed for this call.
11/2/2010 12:45:14 PM *******************************************************************
Resource replication: Failed to Replicate above resource. Trying next site if available.
Exception: The remote name could not be resolved: 'mdp-ws529651'
Stacktrace: at System.Net.HttpWebRequest.GetRequestStream()
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
at Connectivity.Core.SiteServiceProxy.SiteServiceWse.SignInSite(String fromsite, Byte[] data, Byte[] signature, Guid knowledgeguid)
at Connectivity.Core.BusinessLogic.SiteAuthenticator.a(String A_0, Nullable`1 A_1)
at Connectivity.Core.Operations.Replicator.ReplicateResource(Resource res)
11/2/2010 12:45:14 PM Could not replicate resource 'MCG-B78-SP01-CC00-CD-001-01 00.PDF' version 1 from avaiable sites. Located in the filestore at C:\FILESTORE\TESTVAULT\TESTVAULT\000\000\000\000\000\000\104\104_105_1.PDF.
11/2/2010 12:45:14 PM Replication continuing because orphans were allowed for this call.
11/2/2010 12:45:14 PM End executing event Autodesk.Filestore.Replication on vault 'TESTVAULT' at 11/2/2010 12:45:14 PM
11/2/2010 1:00:07 PM Begin executing event Autodesk.Effectivity.Update at 11/2/2010 1:00:07 PM
11/2/2010 1:00:07 PM Begin executing event Autodesk.Filestore.Replication on vault 'TESTVAULT' at 11/2/2010 1:00:07 PM
11/2/2010 1:00:08 PM End executing event Autodesk.Effectivity.Update at 11/2/2010 1:00:08 PM
11/2/2010 1:00:10 PM *******************************************************************
11/2/2010 1:00:10 PM Could not replicate resource 'MCG-B78-SH02-CV01-MD-010-03 0A.PDF' version 1 from avaiable sites. Located in the filestore at C:\FILESTORE\TESTVAULT\TESTVAULT\000\000\000\000\000\000\100\100_101_1.PDF.
11/2/2010 1:00:10 PM Replication continuing because orphans were allowed for this call.
11/2/2010 1:00:12 PM *******************************************************************
11/2/2010 1:00:12 PM Could not replicate resource 'MCG-B78-SH02-CV01-MD-010-06 0A.PDF' version 1 from avaiable sites. Located in the filestore at C:\FILESTORE\TESTVAULT\TESTVAULT\000\000\000\000\000\000\102\102_103_1.PDF.
11/2/2010 1:00:12 PM Replication continuing because orphans were allowed for this call.
11/2/2010 1:00:14 PM *******************************************************************
11/2/2010 1:00:14 PM Could not replicate resource 'MCG-B78-SP01-CC00-CD-001-01 00.PDF' version 1 from avaiable sites. Located in the filestore at C:\FILESTORE\TESTVAULT\TESTVAULT\000\000\000\000\000\000\104\104_105_1.PDF.
11/2/2010 1:00:14 PM Replication continuing because orphans were allowed for this call.
11/2/2010 1:00:14 PM End executing event Autodesk.Filestore.Replication on vault 'TESTVAULT' at 11/2/2010 1:00:14 PM
11/2/2010 1:05:15 PM Acquired license(251257104) for username(Administrator), userId(2), host(127.0.0.1).
11/2/2010 1:08:03 PM *******************************************************************
11/2/2010 1:08:03 PM Could not replicate resource '' version 1 from avaiable sites. Located in the filestore at C:\FILESTORE\TESTVAULT\TESTVAULT\000\000\000\000\000\000\104\104_105_1.PDF.
Error: Soap Exception ( mesg-id = 634243000835625000 )
Exception: CouldNotReplicate [205] (MDP-WS529651)
Stacktrace:
Server stack trace:
at Connectivity.Core.Operations.Replicator.a(Enum A_0, Resource A_1, List`1 A_2)
at Connectivity.Core.Services.KnowledgeVaultService.GetNonlocalResource(Resource res)
at System.Runtime.Remoting.Messaging.Message.Dispatch(Object target, Boolean fExecuteInContext)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Connectivity.Document.BusinessLogic.FileBL.DownloadFile(Int64 fileIterationId, Boolean allowSync, String& filename, Boolean skipFileSizeCheck)
at Connectivity.Document.Services.FileService.DownloadFile(Int64 fileIterationId, Boolean allowSync, String& filename, Boolean skipFileSizeCheck)
Exception rethrown at [1]:
at Connectivity.Web.Services.DocumentService.DownloadFile(Int64 fileId, Boolean allowSync, Byte[]& fileContents)
I have turned off the firewalls on both workstations, and added exceptions for my proxy settings (IP Address/computer name), not sure what else to try, I am thinking that the syncronization is getting blocked by some policy on the workstation or network, just not sure where.
Any Help would be appreciated
Best Regards,
Brett
Solved by BrettCaldeira. Go to Solution.
Are you able to ping each machine using the machine name? Based on the error attached it looks like the one site is unable to resolve the machine name of the other site.
-Jim
We put both workstations on the domain and did a flush dns, and we could then ping via computer name. As soon as that was running replication is working 100% between our two sites.
Best Regards
