I am using Vault Basic 2013. I wonder how to replace the latest version of a part with the older version of the same part? For example I have a part where the latest version is version 9, and I would like to replace it with version 7, so the latest version after replacement would be version 10 (I supose). Is this possible? The same part is in a assembly so I hope that when I open the assembly the assembly will accept that change without big problems. In this case it will be no problems regarding constraints because changes do not affect on assembly constraints.
Thanks.
Solved by Mike.Carlson. Go to Solution.
