I need to run repairing references utility on Vault Server.
Can i run from command line or scheduled task?
Thank you.
Solved by Olaf.Górski. Go to Solution.
Hello infopsm,
please refer to post by Dave Mink on 21-05-2013 http://forums.autodesk.com/t5/Vault-General/Reference-Repair-utility-Command-line-option/m-p/3930341 stating that this utility does not supports any kind of command line options.
Hope it helps
In addition, the reference repair utility needs to be ran from a Vault Client.
-Hywell
Also, with the tighten rules that we implemented for purging, the RRU tool will/should not be used as a regular clean-up task anymore...
Chear Huat.
