Vault General Discussion
Valued Contributor
dpsmith85
Message 1 of 4 (249 Views)
Renaming and moving files in Vault workflow question
249 Views, 3 Replies
11-15-2011 06:08 AM
I am currently in the process of reorganizing a few files in the Vault and always run into the same issues, so I wanted to post my workflow and see if I am doing something wrong and if anyone has any suggestions on a better way to do things.  My goal is to move files in order to make finding files easier.  Right now one of the issues is that I will move a file, move it to a new folder, and then get the latest version off ALL files AND top level assemblies.  I then will later open the top level assembly, check it out, work on it and then go to check it in except the file is still referencing the old files that are left on the local disk workspace.  So vault will give me an error saying all the files that I just moved are already in the vault and won't let me check them in due to the "file already exists in the vault".  At this point I will have to do 1 of 2 things, undo the check out (losing my changes) and delete the files from the local workspace and reopen the assembly, or go through the assembly and replace all the parts with old references to the new folder.  Either way it's a pain.
-I also realize that if I delete all the old files left on the workspace prior to opening the assembly it's going to correct the issue.  However, when you're moving that many files it's hard to keep up with where the old files are and track them down and delete them.  Is there any easier way to avoid this issue entirely?
Autodesk Professional 2010 and Vault 2010.
-Thanks
Employee
minkd
Message 2 of 4 (246 Views)
Re: Renaming and moving files in Vault workflow question
11-15-2011 09:13 AM in reply to: dpsmith85
I think what you are looking for is the "Workspace Sync" functionality, which I believe is included in Vault Workgroup and above.
See Manage Your Workspace in the Help Wiki.
Dave Mink
Data Management
Valued Contributor
dpsmith85
Message 3 of 4 (230 Views)
11-16-2011 05:41 AM in reply to: minkd
Thank you for your quick response.  The workspace sync does look like a nice function, however, I think the real issue is that vault should automatically update the references to the new file location after the file has been moved.  That's the entire point of the software.  Instead it still links to the old file unless I delete it from my workspace.  Is there something I am missing to make this workout more like it's supposed too?
Employee
minkd
Message 4 of 4 (222 Views)
11-16-2011 12:38 PM in reply to: dpsmith85
I know we greatly changed the whole move/rename functionality in the 2012 release. We now fix dependencies when a file is downloaded rather than trying to fix all the parents during the child rename.  Given that in 2010 we did try to fix the dependencies of the parents, it is not clear to me why this isn't working in your case.
Dave Mink
Data Management
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
