All,
In the first post it is mentioned that there are no SP's installed on Vault
4. The service packs that we have released do have some performance
enhancements in them. While I can not guarantee that they will help solve
your issue I do know that they help rename and copy design in regards to
performance. I would suggest that if possible you upgrade to the latest SP
and hotfixes. If your performance issues persist then we can try and take a
closer look at your data set(s).
Craig
wrote in message news:5084768@discussion.autodesk.com...
I would try to let the rename run overnight. Vault renames every version in
every versions use, so this can take a while.
BUT...................
even on very small assemblies with few versions this appears to take a long
time, over half an hour even.
I have never been given a good answer regarding this, just many run arounds
about the system number of files ending in "I don't know".
Personally I have found Vaults rename and "Copy Design" to be worthless
garbage in real use due to the time they take to complete. These were
ovbiously left out of any benchmarks on how much of a time saver Vault is.
Pete
