Below are the steps for doing a repair of the Inventor install. However, I
am not an Inventor expert so you may want to confirm (in the Inventor
newsgroups, support channel, etc) that this is something that will work for
you. It should work, I'm just not sure if having service pack 3 has any
impact.
Here are the steps:
1. Launch Control Panel
2. Launch Add/Remove Programs
3. Select Autodesk Inventor 10
4. Click on the Change button
This should start the Inventor install with Modify, Repair, and Remove as
options. I was suggesting you do the Repair option.
wrote in message news:5136560@discussion.autodesk.com...
Vault and IV 10 service 3a
Both are up to date. I'm the only cad guy so we do not have another system
to try it on. What is the suggestion (steps)for a repair to IV.
