Pumbaa,
Could you tell me what version of Vault/PS you are using and what version of
Inventor etc. Im just guessing for now but maybe there is something wrong
with Vault knowing what version of IV to use to rename the files. You should
have no issues renameing a file that has a parent in the situation you
describe. Is there anything special about your test data set or is it very
simple?
Let me know and lets see if we can get this figured out for you.
Craig
wrote in message news:5126134@discussion.autodesk.com...
I am having problems with renameing files in vault. I created a test part,
and renamed it without a problem. I then created a assembly, and rename it,
HOWEVER as soon as test part got used in the test assembly I could no longer
rename it. Same thing happened when I created a test drawing and put in the
test assembly. The wizard tries to do the rename but gets a error that say I
need to contact support. Has anyone seen this before?
