I have an .ipt part drawing saved in vault, as it turns out what I need to do is convert the .ipt into a .iam.
Being new to vault is there a way to to this, which I'm sure there is I just can't seem to locate the process.
Any help would be appreciated. Thanks
Tiger
Usually an Inventor .ipt file is a single part, like a nut or bolt. An Inventor .iam file is an assembly, like a car. You will have to use Inventor modeling tools to convert an .ipt file to an .iam file.
If the .ipt was created with multi-bodies, it can be used to create an iam file, but that is an Inventor question, not a Vault one. See http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-8E641EB9-90E7-40AB-ACC6-222CB613E712 for the basic technique.
Steve Walton
