Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Rename don`t update iProperties
7 REPLIES 7
Message 1 of 8
140 Views, 7 Replies
When we use rename in VE4 the "part number" attribute in iPropertis do not update.
I have deleted the local copy, tried get latest....
Is this a known issue or??
regards Svein
7 REPLIES 7
Message 2 of 8
mount_mordor
Whoooooooo!!!!!! Someone else on my side!
Oh and it had sure better be a known issue, and they had better be working on a solution for the next release.
The fastest thing I have found is to use YIPPEE, and have the columns show the part number and filename, and then just type the partnumber in, referring to the filename.
Message 3 of 8
Hi Svein,
We are aware of the situation regarding Part Numbers not being changed when
a rename takes place. Thank you for your feedback.
Craig
wrote in message news:4957044@discussion.autodesk.com...
update.
regards Svein
Message 4 of 8
Is this issue fixed ?
Or is there anyone that have made a tool for updating the Part number after renaming ?
Message 5 of 8
see attached image... are you checking the update part number checkbox?
Message 6 of 8
karthur1
Is this a screen shot from Product Stream? Autodesk Vault does not have this feature.
Message 7 of 8
The new Vault (the one that is now in beta or something) got this function, but Vault 4.0 don't...
Message 8 of 8
karthur1
Great to hear that !!!
Does it have a print function?
