Error 111 indicates that there in, indeed, a permissions problem relative to
the filestore. I'm assuming that you have Vault 4. Do you have Service Pack2
installed on all clients and the server? It's not required, but I would
install it unless there's some reason that would keep you from doing so.
Most likely, you're getting an Error 111 because the Vault filestore folder
lacks permissions for AutodeskVault user. This is a local user created when
you install the Autodesk Data Management Server 4 (again, assuming Vault 4
here). If the filestore is in the default location then you shouldn't need
to worry about these permissions. If the filestore has been moved to a
non-default location you'll likely need to apply the permissions for
AutodeskVault with full control to the root folder in the filestore and
apply to all files/folders contained within (using Advanced button).
Could you perhaps let us know that if the assumptions I'm making are on
target?
Vault 4?
Default file store and database locations?
Are you logged into Vault as administrator?
Lastly, if you can get us a copy of your most recent vlog file (after you've
reproduced the problem), then we can probably give you a better idea of
what's happening. The vlog would be found here for Vault 4:
c:\documents and settings\All Users\Application Data\Autodesk\Vault
server\filestore
Bob
wrote in message news:5075355@discussion.autodesk.com...
This problem has merged into ERROR 111 : An error occured while attempting
to access the file store.
Anyone know about this one? I have tried the permissions trick and the
purge with no luck. Why all of the sudden this message? Everything going
fine for months...
