I have defined certain life cycle states for Particular categories inside vault ,
For examplae
Work In progress
Under Approval
Under Review
Under Control
Released
Now I want to delete the Transition from Work in Progress --> Released
Is there a way by which I can eiter delte or Deactivate a particular transition.
Regrads
Prashant Kumar
+91 9958018731
Prashant,
You will not be able to delete the transition - but you can remove permission for users to go directly from WIP to Released. The option will even be hidden in the change state dialog.
To do so, edit your lifecycle and select the WIP -> Released transition
(see attached image)
Now when you go to change state when in WIP, the option to go to released will not be shown (see below)
