Vault General Discussion
Active Contributor
21 Kudos
Post 1 of 4
Refreshing a saved plotlist
133 Views, 3 Replies
02-16-2012 01:56 AM
if you crate a plot list with the plot manager and save the plot configuration to a file, the plot list saves the exact version/revision of the drawings - which is ok.
Help says that you are able to "refresh" the saved list and that the drawings from the list then update to the latest version of the drawing if you want to. i experience that the refresh button does NOT update to the latest version/revision of the drawings. does anyone have the same problem / does it work for you?
We have vault coll 2012 installed.
thx
klaus
1 Kudo
Post 2 of 4
Re: Refreshing a saved plotlist
02-23-2012 01:17 AM in reply to: katterbauer
Thank you for posting this issue.
Please make sure there are differents between the saved version/revision and latest version/revision. E.g. File Name, Plot data, Thumbnail, or add/remove a sheets... we will add the latest verison of the file to the plot list auto.
So could you please give me detail workflow then I can try it?
Carrie
Active Contributor
21 Kudos
Post 3 of 4
02-23-2012 06:10 AM in reply to: katterbauer
i changed the physical drawing between the different versions and revisions.
this results in updating the drawings automatically to the newest VERSION within the specific revision. It does NOT update to the latest version of the latest revision (it does not make a difference it the latest version is released or not).
to try:
1) create drawing - version 1, revision 1
2) save plotlist for drawing with version 1, rev 1
3) change drawing - version 2, rev 1
4) open plotlist - it opens with version 2, rev 1 ---> OK
5) release drawing, version 3, rev 1
6) take drawing in change again, change something and check in drawing - version 4, rev 2
7) open plotlist - it opens with version 2, rev 1 (OK in my opinion)
8) use "Update" in the plot list manager --> still version 2, rev 1 (NOT OK, should be version 4, rev 2)
hope this helps,
klaus
1 Kudo
Post 4 of 4
02-27-2012 12:25 AM in reply to: katterbauer
Hi klaus,
Thank you point out it. The workflows are very clear.  I also met the same issue.  The saved list does NOT update to the latest version of the latest revision. I have logged a defect to track it.
Carrie
Post to the Community
New Post
Announcements
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
