Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Reference Repair Utility - Error Invalid User
9 REPLIES 9
Message 1 of 10
Crstiano
882 Views, 9 Replies
I receive this message when I try use the Repair Utility.
My user is administrator privileges in Vault.
Any idea??
Cristiano Oliveira
Developer Addins | Consultant CAD/PLM | CAD Manager
https://www.ConsultCAD.com/
9 REPLIES 9
Message 2 of 10
smithmat
in reply to: Crstiano
Vault paths use forward slashes "/" unlike file paths.  Can you try with forward slashes and see if that is the problem?
Message 3 of 10
Crstiano
in reply to: smithmat
Hi Smith,
the same error.
Cristiano Oliveira
Message 4 of 10
smithmat
Ok.  I think it wants a path to a *folder* where you want to repair references.  I don't think there is an option to choose a specific file only.  See:
http://help.autodesk.com/view/VAULT/Help/ENU/?guid=GUID-ED03CA1B-4CC3-4774-BFC8-3DA0AEBA8895
- Matt
Message 5 of 10
Crstiano
Well,
Too not. And with slashes unlike...
Cristiano Oliveira
Message 6 of 10
smithmat
I'm sorry, I didn't understand what you meant by that last post.
  • Is it working now with specifying just a folder (e.g "$"), or is that not working either?
  • Or is it that something else is not working?
In your image, the project path should be using forward slashes as shown in the below link (though I'm not sure if the software considers that an error or fixes that for you):
http://help.autodesk.com/view/VAULT/Help/ENU/?guid=GUID-561774F6-7BF4-42A3-A714-5855496F262E
- Matt
Message 7 of 10
Crstiano
Sorry my last post, I expressed myself badly.
The project path, i try with slashes both ways...
The Vault is working GOOD, its dont have a problem, but I want use the PURGE, and this case, need use repair utility. 😞
Cristiano Oliveira
Message 8 of 10
smithmat
Okay, I would use forward slashes for the project path.
The original error you showed is referring to the path on the main dialog, not the Inventor Project File
Did you change the path in the main dialog to specify a folder (like $)?  And did that change anything?
Can you show me both settings and the latest error message you receive?
- Matt
Message 9 of 10
herrerh
In the images attached, you show your Path and Inventor Project File Path.  However for Path, you point this to a project file also, I believe this should only point to a directory.
-Hywell
Hywell Herrero
Data Management Support Specialist
Product Support
Autodesk, Inc.
Message 10 of 10
Crstiano
in reply to: herrerh
Ok. Now run correct.
The Path is need only path. But in the options need PATH + FILE.ipj
Thanks you guys, Matt and Hywell.
Cristiano Oliveira
