C3D 2012, Vault Workgroup 2012
I just Checked in an existing C3D project. As I'm new to Vault, I brought the files in one at a time so I could see any problems with individual files (it's a very small project.) After a couple of false starts, I got everything in where is should be, and everything appears to be working. The only thing I need to resolve is why there are red x's on the file icons (see attached.) These only show up in the C3D Toolspace Projects tree. They do not show up in the Vault Client app.
Thanks.
Hi There,
You should be able to safely ignore this, the red cross simply indicates that the corresponding file is currently not open in C3D. This was removed altogether in 2013 (probably because it confused users :))
