Every Vault I upgrade fails to install the new content center libraries, due to this error message.
This is tiresome, as the time I use to install the libraries manually could be used to perform other tasks. This error has been present at least since Vault 2010...
When will there be a fix?
Thank you for contacting Autodesk Technical Product Support. Please take a look at this Hotfix.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14550729&linkID=9261341
Autodesk Support Team
