In the readme, it says that if a "non ENU version of Vault Basic server, first run "Autodesk Vault 2014 Pre SP1
(Server).msi"".
What is the non ENU version? I am guessing since I dont know what it is, then I dont have it.... but you never know.
Solved by chearhuat. Go to Solution.
DarrenP
ENU stands for ENGLISH version.
Chear Huat.
Hi Chearhuat
. . i am having trouble seeing Vault after installing SP2 for IV 2014.
the advice i am now being given to attempt to fix the non 'loading of Vault',
is described under ENU section of the 'install read me'.
is this likely to bring back the Vault ribbon
i have tried -
Inventor vault addin manager defaulting to unloaded,
after SP2 update 2014 on both Vault & EDM.
i am logged in to Vault, but can’t see Vault in inventor.
i do not have a second EDM addin with a file mscoree.dll
all without success. i have no vault ribbon.
and the step after that apparently is to reload IV.
Any Ideas
i am a single user on stand alone PC using Vault Basic
Thanks MatB
Thankyou Redstack formerly Imaginit Australia,
for giving me acces too Max,
who correctly suggested i open the Vault Uninstall / Repair
and turn on the Inventor Add in.
i lost vault ribbon after Inventor 2014 Vault Service Pack 2 Update
Thanks again RedStack - MatB
