Both wiki-help (http://wikihelp.autodesk.com/Vault/enu/Help/Help/0170-Administ170/0205-Client_A205/0207-Administ207/...) and local help (http://crackingthevault.typepad.com/crackingthevault/2013/09/autodesk-vault-help-for-2013-and-2014.h...) state that Document Editor II role (guess it is about "Document Editor (Level 2)") is enough for performing file version purge.
But "Purge fles" action is absent from the list of actions for this role.
I wonder does it mean the help is misleading and only Administrator could execute Purge on files?
Week have passed. Case 08818675 was auto-created but nobody from tech-support seems to be even bothered.
Unfortunately I should admit that such Vault support team attitude become usual nowadays.
I think the Purge File Versions Role is for the Administrator only and is for purging through the ADMS Console.
In the client interface, if you have delete rights (Doc Ed 2), then you can purge in the Vault client on individual files. Not globally.
-Hywell
Have you checked to make sure that there aren't any permissions on the file? Or Folder restrictions at the folder level?
I ran through the process on my Vault with a DocEd2 user and did not get a 303 error.
-Hywell
I don't believe that deletes the file. If you add a new fiel to the vault, version it i few times, try purging against that. Make sure that you are able to delete the file as well.
-Hywell
Hi Maxim,
Please make sure that purge is enabled on your Vault.
LOL, I forgot that one detail to check.
-Hywell
