I’m having trouble publishing visualization file on vault I keep getting an error on certain files and I can’t figure out why.
All my drawing in their properties has visualization attachments saying system but the ones that come up with an error say none. Is there anyway to change this
Is this the problem? Any ideas would be appreciated pictures shown below
Cheers
Chris Rodway
Solved by chrisrodway. Go to Solution.
Solved by ihayesjr. Go to Solution.
Pull the file out of Vault, open it with the CAD application that created the file and try to manually create a DWF file.
Usually there is a problem with the file and not Vault.
Thanks for the reply,
Yea It looks like your right, it seems to be that vault doesn't like our old border and errors
while making an Visualization file
I have to re-draw it and check it in
Thanks For the input
Chris Rodway
Design Engineer
Sheffield, UK
