Question translated into English:
Title: PS 4.5 Setting
Content: Mail notification will be sent to the corresponding routing participant with the related information when ECO status is transferred. Is there any specific setting document? Thanks.
Answer:
In PS 4.5, you can set the mail notification available by changing the config file.
1. Locate the Web.config file. By default, this file is installed in: C:\Program Files\Autodesk\Data Management Server 4.5\Server\Web\Services
2. Open it by Notepad
3. Find it by the string "EnableEmail"
4. By default, the value of the EnableEmail key is 0. Change the value to 1
5. Locate the SmtpServer key directly below EnableEmail. By default, the SmtpServer value is set to localhost. Change the value to the machine name of the SMTP server on your network. If you do not know the machine name of the SMTP server, contact your system administrator
6. Locate the FromEmailAddress key directly below the SmtpServer key. The FromEmailAddress key specifies the "from" address to use for the automatically generated e-mail messages. This value is blank by default. An e-mail address must be entered.
7. Save the Web.config file and exit the editor
8. Launch PS 4.5 client
9. Select Tools > Administration > Security tab
10. Click Users button
11. Edit the user who is the routing participant
12. Add the valid mail address
Hope this helps.
Tommy
回答:
在PS4.5中,可以通过设置配置文件来使邮件通知功能可用。
1. 找到Web.config配置文件。该文件默认是在C:\Program Files\Autodesk\Data Management Server 4.5\Server\Web\Services
2. 用记事本打开
3. 搜索字符串"EnableEmail"
4. 默认情况下,EnableEmail的值是0。更改为1
5. 在EnableEmail下方可以看到SmtpServer。默认情况下,SmtpServer的值是localhost。更改这个值为你所处的网络的SmtpServer的机器名。如果你不知道SmtpServer的机器名,请与你的系统管理员联系。
6. 在SmtpServer下可以看到FromEmailAddress。FromEmailAddress指定了自动生成的邮件的邮箱地址。默认情况下这个值是空的。必须输入一个有效的邮箱地址。
7. 保存设置并退出
8. 打开PS4.5客户端
9. 选择 工具 〉管理 〉安全
10. 点击用户按钮
11. 修改那些是ECO参与者的用户
12. 添加有效的邮箱地址
希望这个能有帮助。
此致
敬礼!
Tommy
Message was edited by: TommyQian
