Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
PS 5 and Vault 5 on same server
1 REPLY 1
93 Views, 1 Reply
Hi.
Is it possible to run PS 5 and Vault 5 towards the same server,
let's say that Vault users and PS users have different Vault instances
or the same vault instance to work against.
I've heard that the same ADMS is used for both products, and thereby
I've found possibilities for this scenario.
What can be done and what can't?
- Henrik Andersson
1 REPLY 1
Only one server may be installed on a machine. If you have a Productstream
server, it will support both Vault and Productstream users. You can
certainly have separate vaults for each user set, if that's what you want.
Or, you should be able to have a single vault that supports both vault and
productstream users, provided they're all using the same client version.
Jeff
"Henrik Andersson" wrote in message
news:5119327@discussion.autodesk.com...
Hi.
- Henrik Andersson
