Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Property sync and file association issues.
1 REPLY 1
kprom
384 Views, 1 Reply
We have a few problems with the latest version of Vault.(2013 Basic)
When we change a property with Edit Properties, then get lastest version, the fields don't sync.  If we change the sync to one way(Vault to local) it works, but with two way it doesn't when the field is blank.  If there is something in the field, it will work, but if it's blank it will not sync from Vault.
Also, we have an occasional problem where after a rename or copy design, the drawing will lose it's assosiation to the part.  When you open the part it will go find another part with the old name and relink it to that.  We have to be careful to delete the old file and manually relink it to the correct part.
Any ides?
Inventor 2013 update 1.1
Vault 2013 update 1
1 REPLY 1
kprom
in reply to: kprom
Are there any patches or progress on this?  This seems to be happening a lot lately in Vault.  File's keep losing their associativity when renaming them.  If I rename during a copy design it doesn't seem to be a problem.
thanks
