With a normal autocad or inventor file, if a property doesn't exist within the file and the mapping is set to create one if it doesn't exist, then it will create it without issue....
Is this same behaviour support for AutoCAD Block Attributes? I would assume it won't be able to add an attribute to a block in the same way it could a property/field to a file.
If it is set to Yes, I would hope it just ignores it without causing a crash?
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
