Hi
I am trying to insert properties from the Behaviours/Properties area to the Properties grid (System) and viceversa remove ones that we don't use.
Can this be done??
Gareth
Hi Gareth,
What version of Vault are you using?
Hi Gareth,
OK, wanted to be sure before I led you down the wrong path - there are 2 parts to this:
The property Grid on the right of the window shows all the properties associated with that file(s), not necessarily all that is available through the admin tools.
If you create a new property and associate it to a file category, it will not appear on a file unless it is newly checked in to Vault or its manually added to the file (Actions - Add or Remove Properties). So using Add/Remove you can change what properties are associated to the file.
You are never able to remove a system property but you can hide properties - at the top of the property grid you should see "+/-" buttons that allow you to add or hide properties from the grid, not affecting the properties associated with the file, just whether you see them or not.
I hope this helps.
hi Pim,
it's stored at C:\Users\<OS user name>\AppData\Roaming\Autodesk\Autodesk Vault Professional <version>\Objects\Preferences.xml
Hope it helps
