Vault General Discussion
Active Contributor
12 Kudos
Post 1 of 4
Project file .ipj will not checkin
189 Views, 3 Replies
07-27-2012 06:45 AM
I have in my vault 2 versions of my designs.ipj file.  So I've done this before.  Now I made some changes (or i think i have) in the last month without having a checkout to the designs.ipj and I want to check in the new version.  So I've tried checkout without download, checked with download then copy over the file in the working folder, but either way vault (basic) won't accept the checkin.  Well, it performs the process, but I still only have 2 versions shown in the vault and the date is still 1 month old.  Help?
Scott G.
Using Inventor 2013/2014 and Vault Basic since 2012
Using Simulation Flow 360 since 2013 (sparingly, bear with me please)
6 years Solidworks (v2006-v2010)
10 years Pro-Engineer (v13-WF2) w/ Intralink (2.0-3.0) w/ Pro/Mechanica
2 years of Mechanical Desktop
AutoCAD since R12
First professional CAD: DrafixCAD
Employee
8 Kudos
Post 2 of 4
Re: Project file .ipj will not checkin
07-27-2012 12:24 PM in reply to: sgold
Are you sure the project file iteself has changed?
If you do a check-in and Vault detects that the file has not actually changed it will actually do an undo checkout.
Scott Mollon
Quality Assurance
Be sure to check out the Vault Help Wiki!
Active Contributor
12 Kudos
Post 3 of 4
07-30-2012 04:43 AM in reply to: mollons
There's been a date change, but I suppose its certainly possible no actual settings in the .ipj were made.  I didn't purposely make any changes, but its a new installation all around here, so I'm constantly teaking things out, I don't recall making specific changes to the project file. Figured safe than sorry to check in.  Actually nice to know there's that feature to prevent millions of extra copies of the same file stored.  Is it a bit to bit comparison, so even if the file (say its a part file) have different dates, the data inside is compared?
Scott G.
AutoCAD since R12
Employee
8 Kudos
Post 4 of 4
07-30-2012 07:49 AM in reply to: sgold
Vault has logic to handle any changes due to dates only changing.
There are number of things Vault uses to determine whether a file has change or not and dates are accounted for in that process.
Scott Mollon
Quality Assurance
New button for Platinum & Gold Subscription customers
Gold & Platinum Subscription customers can alert Autodesk if they require assistance with their forum post
Manufacturing Community
