Suddely I am having problems loging in to Vault Basic 2014.
I am a single user and have Vault 2014 server and client installed on the same machine.
This configuration has worked flawless fo more than a year, and suddenly today I recieved this error message.
Any ideas where to start?
Best regards / H. Nilsson
Solved by Olaf.Górski. Go to Solution.
Can you log into the ADMS Console?
Something must have changed, install any Windows Updates lately?
Update your Anti-virus? I only ask as I had a system running Comodo A/V and it caused me grief with Vault
Mike
No problems with ADMS console.
However I have checked and a Windows update KB2970228 was installed some days ago.
Perhaps uninstalling this update?
I am using McAfee anti- virus, but I don't recall any major update lately.
Just lucky I have a complete backup of my entire working folder to work with until the problem is solved.
Perhaps the time has come to take a step to Vault 2015??
Cheers / H. Nilsson
Please consider the solution recommended in Autodesk Knowledge "Error: "Error: "Operation failed" on login or "There is an error in XML document (0, 0)." on backup".
Brilliant solution!!!
I feel I cannot thank you enough.
Simply renaming the xml file and restart did the trick.
Again thanks for your help / H. Nilsson
