Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Problems after installing Vault 2014
5 REPLIES 5
karthur1
848 Views, 5 Replies
Installed Vault Server and Cleint 2014.  Still have Vault client 2013 installed.  When I open Vault Basic 2014, I see the files in the grid, but the icons dont appear.  I see the same icons in Windows Explorer.  Did a repair install on Inventor Pro 2013 and rebooted.... still no icons.  Looks like this from windows explorer.
I ran Inventor 2013 (as Administrator) and that did not help.
 How do I get the icons back?
Below is what I see.  On the left is from the Inventor>File Open Dialog and on the right is from Windows Explorer.
Also, In Vault Basic 2013, when I open this, there are no files in the grid.  I can see folders, but no files.  I thought that Vault Basic client 2013 was compatible with ADMS 2014.... Is it not?
5 REPLIES 5
karthur1
in reply to: karthur1
Got the icons back.... Magically started working correctly after I ran as administrator.
Still have the problem with Vault Basic 2013 not showing any files.
gaol
Hi
Lily
karthur1
Correct. No files show in folder. Best I can tell, it is all the folders. I didn't go thru all of them to check. The ones I checked, no files shown in them. There should be Inventor files there.
gaol
Hi Karthur1,
Are you using .Net 4.5? There is a known issue that:.Net4.5 is not compatible with the Vault 2013 client.
The SP1 has solved it:http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21017345&linkID=9261341
Hope this can solve your problem.
Lily
Do you have a filter applied?
