Hello i have a problem with my ribbon in Vault web Client or Busszaw preview.
(look the picture attached, in the red box)
Any idea.?
Solved by plembourg. Go to Solution.
The message you are seeing is part of the Autodesk Design Review (ADR) ActiveX web control which is used as the preview mechanism in both the Vault web client and in Buzzsaw. What is the make and version of the browser you are using?
Thanks for your answer.
I'm using IE8.
In fact i've solved the problem by uninstall ADR 2012 and reinstall it via Buzzsaw options.
Now all it's ok in the Vault webclient 2012 and in Buzzsaw.
Best regards
