After investigating several issues caused by doubing Item revisions (created by using "Skip Revision Bump" option) our company's managment asked us (CAD department) to disable this option for users.
We've created the Vault Explorer Add-in that hooks Create Item window with option "Skip Revision Bump" enabled and blocks its acception.
It works fine but .... some time ago we discovered that user could change Item revision even without "Skip Revision Bump".
Steps are:
1. Change Item state to Obsolete
2. Change Item state to WIP.
Is it ok that user could change Released Item revision ?
I think NO but would like to hear some comment from developers.
I'm not a developer, but just an opinion here. If you have disabled the Skip Revision Bump, and you have users going out of their way to find a way to skip the revision bump by the procedure you mentioned... that is a disciplinary issue. My opinion.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
You could add security to the transition from released to obsolete so that only certain users (or no-one) can perform that transition.
-Dave
@Maxim-CADman77 wrote:
Yes it is
So we need some technical ( not just organization solution).
It is too costly to solve consequences of user mistakes.
You'll have to forgive me, since I became a supervisor I can't help but think of the organizational solutions as well as technical. I see something like this and my first thought is to kick some....
Chris Benner
Could you, please, give a hint where could I set such limitation?
PS: As far as I’m not happy from idea to be the only administrator to be able to delete defective Items (move to Obsolete) I think it worth to limit to administrator role not transition Released>Obsolete but Obsolete>WIP.
One way I can think of is to restrict lifecycle changes to Change Orders. On the Change Orders tab of the Vaule Settings. Checking this box makes it so only the Admin can overide the lifecycle changes outside of a change order.
Chris Benner
Dave, could you please detalize a bit your vision of implementation the idea "You could add security to the transition from released to obsolete so that only certain users (or no-one) can perform that transition."?
Unfortunately, the capability I was refering to is in 2015-R2, which was only recently announced and is in the process of going live.
One of the features is that items now use the same lifecycle engine as files, so the lifecycle is now configurable so security can be added to transitions, etc; just like you can do with files.
I had been working on that release for a while so I accidently (and mistakenly) started to think it was part of 2015 - sorry.
-Dave
Ok. I've added bump revision to state change Obsolete > WIP...
