Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Possible to perform Copy Design w/ Vault Client only
4 REPLIES 4
mies07
620 Views, 4 Replies
Must I purchase/install the Vault Server on my standalone machine to use Copy Design? Or can I do it with just the client installed?
4 REPLIES 4
JeffPaquette6500
in reply to: mies07
You don't need Vault server installed on your machine. Client can perform copy design without the server on the same machine.
Jeff Paquette
Data Management Support Specialist
Autodesk, Inc.
mies07
in reply to: JeffPaquette6500
What I don't understand is how to get the files into the Vault so you can perform copy design - don't I have to check them in first (which I think must involve server)?
I have installed the Vault 2014 client,  but it won't launch because it cannot find the server (localhost - see screenshot) What am I missing here?
JeffPaquette6500
in reply to: mies07
Vault is a client & server application. This link may help: Vault Architecture
You will need to have Vault server installed. It doesn't necessarily *need* to be on your machine, but it can be.
Vault server & client can be installed on the same machine. I hope that helps.
Jeff Paquette
Autodesk, Inc.
mies07
So, then answer to my original question, "must I have the sever installed" is actually "Yes" contrary to your original response
