First, I would guess the RC-80 folder is a subfolder of either
PurchasedComponents or StandardComponents on the network. In looking over
the images, the only discrepancy I find is capitalization, but that should
not be a factor here. I have a similar setup here and I cannot reproduce
this message.
When you get this message with the Place From Vault command and click OK,
does it place the part? If so, what does the Vault browser indicate: a ?
mark or a clear circle (already in Vault).
If you Save and close the assembly before adding the Sprocket, does it open
again without the Resolve Link dialog box? If you use Inventor's Place
Component command, you mentioned that you do not get this message. Does the
assembly still open and resolve the Sprocket?
By all outward appearances, the ipj, Vault Library folder overrides, and
Project Folder mappings look good. Often times, it is a typo that throws a
wrench in.
Is this an iPart Child that you are placing directly by chance? If so, try
to place using the Parent file. Do these files physically exist on the
network?
Brian Schanen
Product Designer - Data Management
Manufacturing Solutions Division
Autodesk, Inc.
wrote in message news:5219058@discussion.autodesk.com...
Brian,
Does this make any sense? Can you see anything wrong with the set-up?
Message was edited by: djblack
