An autodesk user has deleted some files from Autodesk in error. We do not want to restore the whole system. We know the logical name of the file but do not know how to map it to a physical file name. If I knew the physical file we could restore it to a temporary area and then set it up again in Autodesk . I have restored the Autodesk SQL database to a temporary area prior to the delete. Is there a SQL query I can run to find out what the physical path/files name is for the logical file that was deleted in error ? (I am a DBA and have no real Autodesk experience).
Flora
Solved by ihayesjr. Go to Solution.
I would recommend that you perform a full restore on a separate system and pull the files that way. This will be the easiest less accident prone way to get the files you need.
Gee... That would mean finding a place to restore almost 400gigs of files and when I am only missing 2. If I could only find out the path/file name, it would be so easy to restore the 2 files to a temporarary area. Any other thoughts on this ? I guess If full restore is only way so be it .. Thanks.
I agree with Isaac, mostly because I know he knows what he's talking about... a lot more than I do.
btw.. Autodesk is the company name, not the software name. Autodesk has many different software titles, including Vault. Were the files deleted using Vault software, or one of the many CAD software titles? Based on where you posted I think we're assuming Vault.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
.. sorry .. yes its Vault. As you can tell I have pretty much no experience with the software. Thanks for straightening me out 🙂
Here is another option.
All of the previous records will be lost but you will at least have the latest version of the file.
While you could query it from the database, it is complex and we don't support directly accesses the database, although you would be doing it on a temperary setup.
Another thought.... is the file in another user's local workspace?
If anyone has used it recently you could just check it back in from a local copy.
