Having some trouble with vault. Components in the browswer appear with a line through the file name (see below). These components do not follow the parent model into vault when checked in. I am able to open the component by itself and check it in, but would like it to move in with the parent assembly like all of the other parts. Any suggestions as to why i am getting this & how to fix? Thanks!
If you hover your mouse over that part, does it give you any kind of error or warning message?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
No. It states the current vault status (checked in or checked out). Another interesting thing, if i right-click over the name in the browser, all of my vault right-click options appear, but are all greyed out except for the "refresh from vault" option. I tried selecting that, and it seemed like it refreshed, but no changes to the browser in regards to the line & the ability to check in.
Probably a dumb question,... but these parts are not checked outt o a different user, are they? Are the files located outside of the active project?
Is this assembly something you couls attach here? Or maybe a smaller one that exhibits the same behavior?
Chris Benner
Not checked out to a different user, or outside of the project file. What's also a little strange is that I have been able to at times fix it by joggin the model through a couple of changes, saving and refreshing the vault browser. It doesn't work every time and sometimes then another item will lock up in the same manner. It's just happening too randomly to pinpoint when or why.
I'll try to make it happen in a smaller model that i can share with you...
