Hi everyone,
I was hoping if someone could help me out with pack and go feature
Issue I am having is that if i use pack and go feature on inventor files, it maintains the folder structure in the directory that i specify in pack and go e.g. lets say i have an inventor dwg in vault stored at
prjoect explorer --> standard--->Test Folder---> inventor_file.dwg
If I now use pack and go and specify the the desitnation folder to be lets say C:\\Streamline
the pack and go then creates a compelete folder structure inside the folder C:\\ Streamline such that the inventor_file.dwg is located at C:\\ Streamline\standard\Test Folder\ inventor_file.dwg
which is excellent and thats exactly what I want it to do BUT
If I have an Autocad Mechanical file(dwg or dwf) in
prjoect explorer --> standard--->Test Folder--->Autocadmechanical_file.dwg and if then follow the same procedure and point pack and go to
C:\\Streamline expecting that it would copy the the file into C:\\ Streamline\standard\Test Folder\Autocadmechanical_file.dwg
instead it just copies it into the top folder C:\\Streamline and does not create or duplicate the folder structure from the vault.
Can anyone please help me with I would greatly appreciate
Hello and thank you for posting this issue. I have reproduced it on my environment and reported the issue.
Adam
Hi Adam,
We are seeing a similar problem running Pack and Go. We are seeing the problem on a system running Inventor 2012 with W7-64bit and two disk drives - but NOT on one of our older systems running Inventor 2012 with 32bit-XP-pro and a single drive.
Has any solution been found for this issue? We are using Pack&Go as a method of getting our Assemblies vaulted.
It seem that on the W7-64 system, during the Autoloader portion of the our Vaulting process the Autoloader starts looking Outside the Pack&Go Project files Search Path.
I have followed up on this issue and I have been told that this is no longer reproducible on the 2013 release. If you find otherwise, please let us know.
Adam
Unacceptable answer!!! This is a problem with new 2012 installation! We do not have 2013, so I need it Fixed ion 2012. We did not have this Problem in out previous Installatioon ...2009... YES. THIS IS THE REAL WORLD!
I was not referring to the autoloader issue.
Adam
I have moved my issue to a Thread more related to the AutoLoader Issues. reading between the lines - I think this is what should have been suggested - instead of saying the Issue was fixed in the unreleased 2013.
http://forums.autodesk.com/t5/Autodesk-Vault/Autoloader-Issues/m-p/3238340/highlight/false#M39630
Hello dblanchard,
Thank you for the follow-up. I think moving the autoloader issue is the appropriate thing to do.
Adam
