Vault Forum
Welcome to Autodesk’s Vault Forums. Share your knowledge, ask questions, and explore popular Vault topics.
Outlook and Vault
5 REPLIES 5
amasva
733 Views, 5 Replies
Outlook and Vault
Hi
I'm testing the outlook add-in for Vault Collaboration.
I have installed the add-in.
I have logged in to vault from Outlook and checked in a couple of mail.
When I open the Vault client the mails are in vault. So fare so god.
But when I'm trying to map the mail properties I get in to problems. I creates a new property in vault as an administrator, choose mapping, browses to one of the mails and select it. The message that then appear on my screen says: "The selected file did not contain any mappable properties"
What have I don wrong?
Both machines are Dell Latitude D630 wit windows 7 x64. (Both test server and test client)
By the way, I have installed "Microsoft Windows Desktop Search" (on both machines just to be sure)
I have also found the MSG extension and set the index to Index Properties Only.
Asle Martin Svastuen
Autodesk Product Design Suite Ulitmate 2012 Sp1 / Vault Collaboration 2012 Sp1
HP EliteBook 8560w
Intel(R)Core(TM) i7 CPU Q 720 @ 2,0GHz 2,0GHz
16GB RAM
Windows 7 X64 SP1
Tags (1)
5 REPLIES 5
PACDrafting
in reply to: amasva
Has this issue been fixed for 64bit environment?
I'm trying to get his implemented in our office.
cbenner
in reply to: PACDrafting
amasva
in reply to: amasva
Hi
I would like map the email's property in Vault so that I can see the subject, sender, date etc. as a property in vault. I would also like to add other properties to the email that I can fill in manually. This so I can easily find the email or perform a search for a email.
HP EliteBook 8560w
16GB RAM
Windows 7 X64 SP1
PACDrafting
in reply to: amasva
I want to use it to generate reports in vault pro on emails details incl. all email properties.
tom.dedrick
in reply to: amasva
Asle,
Did you get a resolution to this?
I just experienced the same problem as I also wanted to take a look at this ability.
TomD
